show windows as symbolic when above or below cut plane
heathldesign
I have windows in a wall at different heights and so the cut plane can only "cut" one window or the other, but not both. how can i have them both showing in the same view? i read a post from 2006 that says the symbolic floor plan display shows the window as cut regardless of the cut plane setting, but that must have been changed since then.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.1. AC 27, 6000 USA
You need to set your wall as symbolic as well.
ooooooh. yep, that worked. i have to say that i find the user guide seriously lacking in instruction. didn't mention that in anything i read.
once again, thanks Barry
