dhnguyen
slanted opening
Good morning,
I have a 2ft thick curved wall and it has many openings in it. All of the openings have different dimensions on the inside face verses the outside face, please see attached plan and photo for an example. I tried looking in the "simple window opening" or "simple door opening" options to see if i can manipulate the opening dimensions on each side - but there is no options for that.... How do you draw this kind of opening?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
1 Reply 1
Hello dhnguyen,
I do not use AC18 since few years but there is a special window to do this into Archicad library.
Then into brash parameters you can input these parameters :
By this way you are able to create this kind of wallhole :
3D
PLAN
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
