small light to put above a bathroom mirror.
Hi, Im looking for a small light to put above a bathroom mirror.
Has anyone got a link??
thanks
2 Replies 2
In the ArchiCAD default library there are quite a few.
Go to the Lamp Settings Dialog and under Interior Lamps 18 you will find them.
For example the Ceiling Lamp or Recessed Spot lamps may be what you are looking for. You can set their size to the desired values.
Thank you laszlonagy, helpful as ever
I did have a look in the AC library, but it didnt seem that the lamps could be modified enough to be used for a mirror light.
Ill have another look with your suggestion
thanks
