In the ArchiCAD default library there are quite a few.
Go to the Lamp Settings Dialog and under Interior Lamps 18 you will find them.
For example the Ceiling Lamp or Recessed Spot lamps may be what you are looking for. You can set their size to the desired values.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
