KeesW
splayed jambs
I am doing a measured drawing and some doorways have splayed jambs. The splay varies on each side of the door from about 45 degrees on one side and 15 degrees on the other. What is the easiest way to create these?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
2 Replies 2
Depending o n the Window object you're using you will have different reveal options. If you're using the default library, you should see something like this: ( see attached image)
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
KeesW
Thank you - you saw the light even from the dark side!
I am a Cadimage window user and it hadn't occurred to me to look at Archicad's own window settings.
