alemanda
steel asymmetric L profiles - bug?
When I chose the Steel Asymmetric L profile and change the thickess of the web I got 0 values in all the mechanic properties of the object.
Seems there's something wrong in those calculations.
I use the Italian standard library.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
6 Replies 6
Erwin Edel
Just checked NL library, I get 0 values there regardles of custom or predefined profiles. I would guess it is a problem with the object everywhere.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
alemanda
Do the other type of profile (HEA, IPE, etc.) work properly?
AC27 latest hotfix
Win 11 Pro 64bit
Erwin Edel
Looks like it.
www.leloup.nl
In my version (AC19 INT) I get this problem with "Unequal Angles Beam 19" and "Unequal Angles Column 19" objects. If I go to the Properties and Descriptions page of their Beam Settings panel in the Object Settings Dialog, all values are zero.
However, in case of all the other objects I checked in that directory, the values are filled in properly.
In any case, this is something I will report to GRAPHISOFT.
alemanda
Yes, this is the same behaviour I get with ITA version.
Thank you.
AC27 latest hotfix
Win 11 Pro 64bit
Katalin Borszeki
Hi All,
This issue has been recorded with AC18, we are aware of it. The Unequal Beam and Column objects send a 0.00 value to the Properties & Description (eg. cross section area) while the values are not 0.00.
As a workaround the User Defined Parameters can be used from the Parameters for Listing section or Complex Profiles can be used, from eg. the import standard steel profiles menu.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
