undock gdl dialog box
Bawar Tanay
is the undock buttons gone? at least i cant see them in the gdl editor.
this is what i mean screenshot.
Operating system used: Windows 28.02
Archicad 16 - 26
Laptop: Alienware M18 R1 | windows 11 pro | i9-13900HX | RTX 4070 8 GB | 32 GB RAM
PC office 1: windows 11 pro | I7-10700 | RTX 2060 6 GB | 32 GB RAM
PC office 2: windows 11 pro | i7-12700 | RTX A2000 6GB | 32 GB RAM
2 ACCEPTED SOLUTIONS
Lingwisyer
Guru
I think someone mentioned that some dark-mode mod they were using was inverting the colour of the button, so it was still there, just blended into the background. Might yours be a similar case?
Ling.
Here is the post Ling mentioned.
https://community.graphisoft.com/t5/Modeling/Missing-Sub-Window-Diplay-Buttons/m-p/628554/highlight/...
5 REPLIES 5
It is still there the same as normal.
Exactly the same as the image yo have attached.
Although I still only have build 3060.
Are you saying it was there before but is not in the latest update?
Latest build is 3110.
I just updated and it is still there.
Lingwisyer
Guru
Ling.
Bawar Tanay
Hi @Lingwisyer @Barry Kelly
thank you both, I forgot about that. sadly, graphisoft still did not resolve this issue after more than one year.
Archicad 16 - 26
Setup info provided by author
