user break
Any one knows how to break script checking process manually? Maybe any shortcut?
Sometimes, if I work with gosub function, not yet finished the script(without inserting "end","goto","breakpoint",etc at end), I push check script button and I'm sure that you know what that's means!
Cmd(Ctrl)+. is the general shortcut for 'stop process'. One of the nice traits of AC's Mac heritage. It will (should) stop the generation of the 3D or section window, and building/checking an object in the GDL editor.
In practice, it's only partly effective. I have had varying success using it to get out of an infinite loop in the GDL editor. Definitely worth a try, since the alternative is force quit/end task.
HTH,
James Murray
Thank you very much James!
