XYZ Location object - some GVs dont work
An ArchiCAD reseller asked me for a simple 2D object that you could place in a storey or a plan and it shows its XYZ location. This takes just a few minutes if you relate it to the world origin.
But theres more to this than just symb_pos_x etc, He was after something that would show it in relation to a local project origin, not the world origin. i found that the global variables GLOB_WORLD_ORIGO_OFFSET_X etc. which are supposed to locate XYZ positions in relation to a Temporary Origin do not work in 9.0, they always come in as Zero, wherever the object or the local origin is. Couldnt find anything about XYZ location in earlier AC-talk conversations.
I also made an object using the SAMPLE script provided by GS to illustrate the use of these GVs, and they dont work in that object either!!
Frank Beister
Hello David,
The two Globals are new in AC9. As I don't believe, that they are not working straight from the start, maybe they have to be used in another environment. As GLOB_SUN AZIMUTH is only available in 3Dmode. Maybe GS can give some hints about it. I tried the sample script too and got only world- and object position.
Frank
