when drawing a 1 foot wide wall,( default settings ) i can view and insert my windows from the window library.
Now when I change my wall settings to 6 inches wide and try to open the window library I get errors up the ying yang: group operation error at line 879 of the 3d script of file wa_trim_us_10.gsm ( this error for pretty much all windows )
when changing my wall settings back to 1 foot wide it works normal again. Seems that the trim doesn't want to work in the 6inch wide wall. why does this happen. is there a relation ship between the wall settings and then opening the window library , that seems odd since I should be able to insert a window in a 1' wide wall somewhere else my model correct ?? while I work on other walls in my model ??
can anyone here explain what is happening, why this error occurs ?? or how to fix it ??
educational version
Mac os 10
intel mac 2.33 GHz
