window and door labels
How can i turn this window label to other side?
6 Replies 6
Try to turn your view
The label places it in function of the rotation of your sight in order to be as readable as possible
It's the same subject about the dimension lines
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
any other solution about it? i want to looks it to right not to left.
felcunha
You can replace it by another label of the library. These other labels may have an option for rotating.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Stress Co_
Turn the window's label off, then (with the window selected) use the LABEL tool.
Select "Builders Dimension Label", uncheck "always readable".
Marc Corney, Architect
Red Canoe Architecture, P. A.
Thank you for answers and for your time.
Stress Co_
Just to correct/clarify my previous post.
Turn the window's "Dimension Marker" to "no marker".
Then, with the Label Tool selected (and the label type set to "Builder's Dim. Label"),
hover over the window (so that it is highlighted) and click.
You can drag/rotate the label as needed.
