window and door labels
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-03-20
01:02 PM
2023-05-26
11:10 AM
Rubia Torres
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-20 05:29 PM
2019-03-20
05:29 PM
Try to turn your view
The label places it in function of the rotation of your sight in order to be as readable as possible
It's the same subject about the dimension lines
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-20 06:04 PM
2019-03-20
06:04 PM
any other solution about it? i want to looks it to right not to left.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-20 06:10 PM
2019-03-20
06:10 PM
You can replace it by another label of the library. These other labels may have an option for rotating.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-20 06:52 PM
2019-03-20
06:52 PM
rocknkaya wrote:Turn the window's label off, then (with the window selected) use the LABEL tool.
Select "Builders Dimension Label", uncheck "always readable".
Marc Corney, Architect
Red Canoe Architecture, P. A.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-20 11:00 PM
2019-03-20
11:00 PM
Thank you for answers and for your time.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-20 11:19 PM
2019-03-20
11:19 PM
Just to correct/clarify my previous post.
Turn the window's "Dimension Marker" to "no marker".
Then, with the Label Tool selected (and the label type set to "Builder's Dim. Label"),
hover over the window (so that it is highlighted) and click.
You can drag/rotate the label as needed.
