ā2006-04-25 12:49 PM
ā2006-04-25 03:22 PM
ā2006-04-25 03:34 PM
ā2006-04-25 03:48 PM
zucoc wrote:This is fine if you can restrict the use to a font that works, assuming there are no cross platform issues, and that you can type the special characters into the script. I haven't tried this in Windows (that I can recall) but getting the GDL editor to recognize the alt+ combinations might be problematic.
simpler solution:
most fonts have the characters "²" and "³"
you find them with the character map tool
for example in the arial font they are alt+0178 and alt+0179
so you dont need a separate string at a location that is hard to calculate
ā2006-04-25 03:55 PM
ā2006-04-25 03:59 PM
zucoc wrote:Thanks for the info. BTW: It does work on the Mac.
on windows it works
you can enter the extended characters in the gdl script editor without problems
can not and will not try on mac
ā2006-04-26 02:20 AM
ā2006-04-26 08:35 AM
