‎2006-04-25 12:49 PM
‎2006-04-25 03:22 PM
‎2006-04-25 03:34 PM
‎2006-04-25 03:48 PM
zucoc wrote:This is fine if you can restrict the use to a font that works, assuming there are no cross platform issues, and that you can type the special characters into the script. I haven't tried this in Windows (that I can recall) but getting the GDL editor to recognize the alt+ combinations might be problematic.
simpler solution:
most fonts have the characters "²" and "³"
you find them with the character map tool
for example in the arial font they are alt+0178 and alt+0179
so you dont need a separate string at a location that is hard to calculate
‎2006-04-25 03:55 PM
‎2006-04-25 03:59 PM
zucoc wrote:Thanks for the info. BTW: It does work on the Mac.
on windows it works
you can enter the extended characters in the gdl script editor without problems
can not and will not try on mac
‎2006-04-26 02:20 AM
‎2006-04-26 08:35 AM
