2007-02-14
10:17 AM
- last edited on
2023-05-25
06:21 PM
by
Rubia Torres
2007-02-14 07:11 PM
2007-02-14 07:12 PM
2007-02-15 02:06 AM
pradeep wrote:This may assist also.
in archicad 10 ver, it is unable tilt/rotate the 3d text object in vertical direction. any help
pradeep
2007-02-15 02:13 AM
2007-02-16 05:36 AM
pradeep wrote:pradeep, on further investigation the following part will allow you to rotate in either 'X', 'Y' or 'Z' axis.
2007-02-16 08:57 AM
Rod wrote:pradeep wrote:pradeep, on further invetigation the following part will allow you to rotate in either 'X', 'Y' or 'Z' axis.
More speed, less haste next time (for me that is)
2007-02-16 08:58 AM
Philip wrote:
The setting is highlighted here
2007-02-16 09:15 AM
s2art wrote:
perso.orange.fr/archilib.od/ also has some 3d text objects which may be of use.
2007-02-16 03:53 PM
pradeep wrote:When you do the animation, check "rebuild for each frame"
i download the waterfountain.gsm , when i used it & did animation it not showing an 3d animation in it(live object).
