Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Archicad display door overhead lines
Hello everybody:
Is there any option in the door settings to allow the display of overhead lines? see attached image.
Thanks in advance
Lingwisyer
Guru
Not quite the overhead lines, but you can turn on the wall contour and change the linetype to hidden.
Ling.
It works great. Thank you very much.
