Conflict between versions.
Can anyone help?
I am working on a project for school. The computer I use at school is archicad 10. I been adding furniture into the plan. I have archicad 11 at home. When I open the plan at home there is no furniture. There is nothing in my furniture library. How can I get more furniture into my archicad? Is it possible to transfer the furniture library from 10 to 11? Also if I work on something from 10 it opens and when I save it from 11 I can't open it in 10. Any help? Ideas? Downloads? Thanks in advance.
3 Replies 3
Ben Odonnell
Check out this thread.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Or you can save in AC10 as an Archive (*.PLA extension) so your placed objects will be there in AC11.
AC10 cannot open AC11 version files.
If you save as AC10 version in AC11 and used AC11 library parts in AC11, AC10 will not be able to read those library parts, because their library part version is higher than the one AC10 recognizes.
I downloaded 11 goodies and downloaded the file that I can use 10 goodies in 11 aswell. The problem is is that some of the furniture is loading and the others aren't. The only thing that shows in plan is a green dot. How can I get those pieces of furniture shown? Thanks!
