Jennifer01
Beginner
Connect Graphisoft ID with license - Garphisoft ID mit Lizenz Verbinden
Hello everyone
I have an educational version of Archicad 27, but unfortunately I am not able to connect this license to my Graphisoft ID. I cannot select Connect Graphisoft ID License in the Archicad License Information under License Management Options.
What could be the reason?
Thanks for your help in advance.
Greetings Jennifer
Joe Logiudice
Graphisoft Alumni
Graphisoft Alumni
Hello Jennifer,
In order to help you should write an email with the email you used to register on myarchicad to edu@graphisoft.com.
We will help you solve the problem!
Giovanni Logiudice
Educational Community Expert, Moderator
Certified GRAPHISOFT ARCHICAD BIM Manager
