Display Wall with cuts in floorplan
Hello everyone:
I cut a wall with spheres using SEO, but I can´t find a way to display the holes made to the wall in floor plan.
Thanks in advance
1 Reply 1
Unfortunately SEO does not show in plan.
You can convert it to a morph and then it should show, but it will be harder to edit in future.
TIP: if you do that, keep a copy of what you used in the SEO in a hidden layer or off to the side so you can change it if needed later and convert to a morph again.
Or you have to add fills and lines in the plan so it looks as you want - that is what most will do.
