2007-11-26
11:08 PM
- last edited on
2023-05-25
06:16 PM
by
Rubia Torres
2007-11-27 01:39 AM
2007-11-27 03:53 AM
s2art wrote:So do you you set your Working Units to surveyors units or degree's ?
TC
If the Oz method is the same as NZ for describing angles, when drawing your line constrain the cursor in the direction of north, enter the distance, enter Angle value followed by - (minus) then hit enter. This will draw your line clockwise from North direction.
Alternatively, if you have the Cadimage Site and Massing tools add-on (we get them in NZ with AC, do you?) use it. Very handy.
2007-11-27 04:01 AM
2007-11-27 05:22 AM
t0pcat wrote:Yep.
Dont worry i worked it out i set it to degrees mins sec's ...
Thanks again
Tony
