odd problem
For some reason I cannot get the little window to pop up when you go to insert a line or a wall to specify the distance or angle. It was working yesterday, and I did not play with any of the preferences since then.
Any ideas on how I can get this back to working?
I'm using 11 on an Intel Mac
Thanks
6 Replies 6
crose
Turn Tracker on. Mine keeps turning itself off every now and again too.
srose
s2art wrote:
crose
srose
Mine keeps turning itself off ALL the time!
Doh!!!
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Rex wrote:
s2art wrote:
crose
srose
Doh!!!
I think in the Work Environment Dialog there is a setting that controls whether the Tracker should be up always or only when needed during an operation.
Eduardo Rolon
Yep, it is controlled from within the WE and it still turns itself off despite the selecting "Always On".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I am having this problem, too. So is everyone else in the office. I haven't been able to identify a trigger, yet. For the time being, I would recommend that we change the term "settings" to "movings."
Philosophical issues between using the Coordinate Box vs. Tracker aside, the Tracker (esp. if using relative / polar coordinates) is one of the easier ways to transition ACAD users over to AC11. GS, please fix this Tracker issue!
Arg
Zolli
__archiben
it's a bug GS is aware of . . . and as far as i'm aware, they are yet to identify the trigger either. my hunch is that it is something to do with error reporting. obscure i know, but i'm sure that report window messes with the work environment when it puts in an appearance . . .
~/archiben
b e n _ f r o s t
