Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
GDL Object Depositiry
New to ArchiCAD. What is the process of adding items from the Object Depository to your library?
1 REPLY 1
Download, then place in either a project specific or office standard folder, which gets loaded with relevant projects.
As a general rule it is suggested that you have three libraries loaded in a project;
AC Library for the version you are using
Office Standard library (your own office-specific objects)
Project library (objects only used in or created for a particular project )
