Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
How can i create a flat roof?
hey, i am making a building from blueprints and i don't really know how to create a flat roof... If anyone could help me, that would be awesome.
thanks, sjones
There would be lots of ways to model a flat roof.
Just a couple of ideas...
How about a roof with 0 pitch, or a slab
Do you need to model the slight slopes that will be required for Roof drainage? Then maybe a mesh.
Does the roof have a constant profile? then try a creating a custom profile.
I'm sure there are many more approaches you could explore depending on your needs.
Good luck
Rick Thompson
You may want to build a composite with the layers (materials) that you need. That composite could be used with both the slab and roof tools as long as you check those boxes.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
