Kolbaszkarika
How to restore an older version of Archicad?
I'm a student and I used to download Archicad 22 but it would be good for me to work in Archicad 23 but the educational licenses only let me upgrade to 24. How can I upgrade from 22 to 23?
3 Replies 3
Eduardo Rolon
AFAIK it is not possible since EDU serial numbers are assigned yearly.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
runxel
Licenses are always downwards compatible. This holds true for EDU as well.
Meaning, a license for 24 can also unlock version 23, 22, 21, etc....
But of course this is one way. License for version 22 won't unlock 23, 24, 25....etc.
You get the idea.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Eduardo Rolon
It is not an issue of compatibility but access. EDU versions have serial numbers that expire yearly and  IIRC if you skip one year then even if you are a student then you will not get access to that version and even if you do, since that version is more than a year old, then the serial for 23 would not be valid.
If you are a student there is no reason to be working in an older version. All my current students are using 25 at this time.
AC29 US/INT -> AC08
