Paopao
Inclined slab and wall intersection
Hi guys,
I have to make an inclined slab. As I can understand I can use the roof pitch tool but what abot the itersection with walls? If I use the Connect command I cut the upper part: how do I cut the bottom part without trasforming the wall into a morph?
Thanks,
PP
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
5 Replies 5
Hello Paopao,
Are you able to share a print screen ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Paopao
Here it is. I awould like to retain the characteristics of the wall because I will have to fix doors, walls, etc...Is it possible without a morph? I want to keep the upper part of the walls.
Thanks
PP
Thanks about this picture !
You are able to connect wall with shell or roof by this way :
Right clic after selecting roof and wall and clic on "single-pan roof connection"
It is possible to connect shell/roof with wall/curtain wall too !
Christophe - FRANCE
Paopao
Yes, Thank you so much Christophe!
You can notice that this operation models a lower rail at the level of the curtain wall.
Christophe - FRANCE
