daviiiiidave
Licence Management via RaspberryPi
(1) Raspberry Pi - Install Rasphian
(2) Download WibuKey Codemeter for Linux/ARM on the RaspberryPi
https://www.wibu.com/support/user/user-software.html
(3) Install WibuKey Codemeter for Linux/ARM
(4) Use VNC Server und VNC Viewer to get remote control for the RaspberryPi
(5) Use the Raspbian browser to get into the webadmin tool of Codemeter. Setup up everything under settings
Dont forget to plug in your Dongle
If you use an VPN you have to check your IP and then add it into Codemeter. On the RaspberryPi the IP of the workstation and on your workstation the IP of the RaspberryPi.
Its not very detailed, but if you have questions while in process just ask
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
Can't you just plug the key into your workstation?
Or are you using the RaspberryPi as a server for network licenses?
daviiiiidave
Yeah but you wanna spread them all among the users.
Our licences are all on a dongle. So yeah i think the right describtion is:
RaspberryPi as licenses server
