Saving AC9 PAE into PLN file to be able to open it in AC14
I was told that to be able to open AC9 educational version files in AC14, I should save the file in PLN format. AC9 educational version has no option for PLN. Please help!!!!
Thank you!
3 Replies 3
It is not possible to save or in any way use data from an EDU version file in a commercial version.
Per the licence agreement one is not supposed to use data from EDU files in their commercial version.
can i do merge?
No, Merge does not work either.
EDU files cannot be converted into commercial version in any way.
