Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Upgrading my template from Educational to Commercial
Hey,
Im running Archicad EDU and about to upgrade to Commercial, Can I still use my template I created or is it forever marked with the Educational Stamp? Is there a way around this if it is marked? Don't really wanna go to the trouble of recreating it all over...
Window XP
Archicad NZE 12
5 REPLIES 5
It is marked for eternity , an educational file cannot be turned commercial.
Otherwise a whole office could work on educational and have only one commercial license to print everything.
Thats what I thought, Just thought maybe I wouldn't have to do it all again
I have never tried but can you copy and paste from the educational version to the commercail PLN?
Also try using the Attribute Manager to bring across all the attributes.
If it works it will beat setting everything up from scratch.
Yeah I'll have a play around and see what I can do,
cheers
I do not think you will be able to trick ArchiCAD in any way.
