Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Licensing
All about Graphisoft ID and licenses: Education, Demo, and more
Wall Colouring - Rendering
When you have a wall that runs along more than one room, and you change the finish/surface of that wall it changes it for every room, how do you assign room specific surface colours? without "splitting a wall"?
Cheers
B
2 REPLIES 2
Djordje
Cheers
B
Use different wall accessories for every room.
It is easier to split the walls.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Andy Thomson
Mentor
This is a good, fundamental modeling question. Recently, I have started modeling finishes (mostly ceilings) as separate assemblies, rather than using purely composites. It is better to do this for complex RCPs, but also for calculation purposes - better than using zones IMO. It might seem outlandish, but thin 'drywall' walls of different colours 'magic wanded' where appropriate may be the answer. Just shut them off on a 'finishes' layer in 90% of your views...it is in fact how stuff gets built, so....
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
