William Yan
help, Publish module file problem. I get *.mde file not *.mod file!!!
hey guys, help,I set to publish module file, but the problem is I get *.mde file not *.mod file!!! Did someone know how to do with it?
AC 26 5002 CHI, Windows 10
4 Replies 4
I am guessing you are using the educational version of the software?
William Yan
yes, exactly, I am using the educational version. Is this the reason? Oh my. Thanks!
runxel
I think the solution in another thread was to rename it. You then can hotlink the module as normal.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
William Yan
Cool operation!
