2010-12-27
11:40 PM
- last edited on
2023-05-25
05:45 PM
by
Rubia Torres
2011-01-04 09:45 PM
rob2218 wrote:I say find a new engineer. What happened to the KISS technique OR show it once principle? Contractors are working in the field at the site. 12 feet finish floor to the next finish floor reads easier than 194.5 to 206.5. What happens if you use precut lumber, pre-engineered timber products or wood with it's nominal dimensions? Now add 109.125 inches (precut stud with bottom and double top plate) or 9.09 feet to 194.5... getting 203.59... now do this at every floor... now change something.
Agreed.
i think the story setting should be set to 0'-0" if this is the "first floor" let's say.
That way you simply equate 0'-0" to a MSL (example 0'-0"=M.S.L. 194.5')
and if the MSL goes up or down or if your building slab needs to be moved up or down...it's based on a 0'-0"=something number.....rather than having to actually 'show' the real world vertical mean sea level number all the time.
But what's happening here is we have a structural engineer who insists on switching over ALL our story settings to the "real" mean sea level numbers. What a nightmare that's going to be for the contractor when he has to figure out and add up strange fractional numbers because our structural engineer decided "IT MUST BE THIS WAY".....
