‎2014-10-11
12:18 AM
‎2023-05-24
08:56 AM
Rubia Torres
‎2014-10-11 12:32 AM
‎2014-10-11 12:47 AM
rgarand wrote:
The only way I have been able to round the corners of vertical walls and arches is to create an inverted 1/4 round and apply solid element operations on all the areas you want a 1/4 round.
After doing this ONCE within ONE room I decided it wasn't important to see these anymore.
‎2014-10-11 01:01 AM
‎2014-10-11 02:01 AM
rgarand wrote:
Since the morph tool is still quite new I am sure Graphisoft is working on this. I wish there was an option to apply this technique WITHOUT turning the object into a MORPH. The last thing I am going to do is turn all my walls into morphs to bullnose the corners.
As for the walls in section, check your Wall Surfaces to make sure they all have the correct material.
‎2014-10-13 03:44 PM
