Terrain displaying in plan view
How can i correctly display a mesh in plan view, if it is a slope and my building is half buried in the terrain. Does the cut plan affect the display of the mesh ? or i have to manually draw the cut surface of the mesh?
Help me please,
6 Replies 6
Erwin Edel
If you convert the mesh to a morph you can probably achieve that.
Save a copy of the mesh before trying it though
Depending on complexity of the mesh, the morph might slow down your plan view though.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I would not like to have it as a morph, if this will slow down my 3D and can't be editable afterwords. I have already a complex project with lots of info and it works a bit slow..So i prefer to draw it up manually..
I saw that it is possible to achieve the cut of the mesh in 3D document...this what i would have liked to achieve in my floor view. Just wondering if that could be possible ..
Thanks for your answer, though..
Try this strategy ( having both a working terrain and a display terrain):
  • - Copy your terrain made with the Mesh tool
    - Move one of the copies to your Hidden Layer
    - The remaining one, convert it to Morph. Note that in Plan and 3D it will look exactly the same, so no cut for now.
    - Select the Morph and change its "Floor Plan Display" to "Projected" instead of " Outlines Only", voilá, there is your cut in plan.
    - Keep your Mesh in the Hidden layer as your working terrain, edit it as needed, and your Morph as your display terrain.
The reason why I keep the Mesh is because in general I'm more comfortable with editing the meshes than the morphs ( for terrains purposes). Needles to say, every time you have an important change on the working terrain (the mesh) you have to create a new updated display terrain (morph).
Hope this helps... it works for me.
Regards
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Regards
Following your logic, instead of creating a morph, I have taken the mesh from the 3D document (where it displays properly), copy&pasted it in a working sheet (there 3D objects are converted in 2D lines and hatches), copy&pasted the hatch of the cut part of my mesh in my floor plan..well..at least I avoid heaving another complex morph in my project that would have slowed down my work. Thank you for your suggestion!
If somebody knows a better idea, please share !
Erwin Edel
If I like the way something looks in 3d document, I just save a top down 3d document with it's own layer combination, modify my floor plan layer combination and place both views on my layout, overlapping eachother so it looks like one view. Sometimes this works, depending on display order of elements. I've used this method with a complex curved roof I couldn't get looking right in floorplan without lots of coverfills.
www.leloup.nl
Cool, I think this is even better idea
Thank you so much Erwin !
