‎2004-04-19 01:05 AM
‎2004-04-19 03:12 PM
ejrolon, take it easy and have a lovely dayjust being sarcastic about Autodesk's marketing department
another Moderator
‎2004-04-19 03:47 PM
stefan wrote:This is pretty much what I was trying to say. The argument over the meaning of "fully" parametric strikes me as specious. Like arguing how many parameters can dance on the head of a pin.
Before you shoot on the claims from Revit, beware that the definition of "fully parametric" is not a very objective one. There is no plain and clear definition of what this is supposed to mean.
In a certain way, changing a cell in Excel and then causing the whole spreadsheet to update and trigger all kinds of VBA-macro's can also be called parametric (if you limit your modifications to the cells that are allowed).
That said, I think both ArchiCAD and Revit can more or less fullfill this claim, although not in the same way. There are many differences between the two of them.
‎2004-04-19 06:16 PM
‎2004-04-19 06:58 PM
another Moderator
‎2004-04-19 07:16 PM
Scott wrote:No, PlotMaker is merely a publishing/layout program. All drawings are WYSIWYG views (if the operator is using AC properly) in AC ... matching exactly what is on the sheets ... and all are merely views of the same internal database. Has always been that way: a common relational database is the core of the Virtual Building.
So in AC, you can open a sheet in Plotmaker, make a change, and then the model will update?
Scott wrote:Yes, since 8.0 when the Interactive Scheduler was introduced. This provides 2-way customizable queries of the building database, allowing both conventional schedules as well as any kind of tabular view of model data that one might want to edit. The limitation at present that I mentioned previously is that these schedules are only editable and updateable from their 'preview' window ... not from the placed schedule (linework and text). To edit or update a placed schedule, it has to be selected (it is a single object), and then the preview window opened (which causes a re-query). There is no option in 8.1 to have placed schedules automatically updated.
Also, changes in schedules? In AC, you can make a change in a schedule, and the model will update?
‎2004-07-07 11:16 PM
‎2004-08-23 07:38 PM
Matthew wrote:Scott wrote:
Personally, I prefer to have the changes propagate only when I want them to. This has always been my primary reservation about Revit. How this difference makes Revit morefullyparametric than ArchiCAD escapes me. The claim to be the first fullyparametric AEC modeler seems a bit like being the first left handedperson to fly solo across the Atlantic.
‎2004-08-23 10:52 PM
david wrote:It's all marketing, and it happens on both sides. What does Graphisoft do now with the marketing that claims ArchiCAD was used to design the tallest building in the world? It was the tallest for a short time, but now the Freedom Tower at the WTC site will be taller, and it's being designed and documented in Revit. Not trying to say their marketing is wrong, but when they say it's the
The reality is that Archicad has been broadly parametric since it began, and that Revit's slogan appears to be designed to mislead all but those technically skilled enough to be able to split those hairs.
The idea of the whole model being parametric is closer to the idea of an API in archicad. Whereby a change in an object or zone might be able to change things elsewhere in the model without human intervention. I agree with Matthew that it would be alarming to have the building changing itself elsewhere significantly because of a small change.I think the concept has been distorted somehow. Revit's parametric capablities do allow you to change any part of the information in any view, even on a sheet, and the model will update. In Revit, I can make a change in a schedule, and the model will update. Soon, I may be able to make a change in the Specs, and the model will update. Yes, there are other parametric capabilities, such as: move a wall, and the doors, windows, roofs, and floors will move as necessary. But if you don't want the roof to update, it wont. Its up to the user to set those releationships, but its really intuitive.
If Revit's definition of parametric means (for example) that by moving a door, the lightswitch and skirting next to the door would have the option to move too, I would welcome that development in AC.Yes, in Revit you could have that relationship if you wanted.
But is revit actually getting anywhere? Seems to me that Autodesk are still promoting ADT!Autodesk is promoting both. They can't turn their back on 250,000 users of ADT, they have to keep working on it. They are also promoting Revit, and giving a ton of support to Revit users, and projects such as the Freedom Tower.
‎2004-08-23 11:34 PM
Scott wrote:Is this a question about ArchiCAD or PlotMaker? You don't "open a sheet in PlotMaker" when you are "in AC" - they are two separate products.
So in AC, you can open a sheet in Plotmaker, make a change, and then the model will update? In fact, I thought most views were initiated/updated by a 'command' of some kind.
Scott wrote:If you are keen to learn about ArchiCAD, I suggest you pay a visit to your local ArchiCAD dealer and/or get the demo CDs. You will learn almost everything you want to know from there, and then you can come back with some informed questions.
Please, don't take any of this the 'wrong way.' I am honestly just trying to become more knowledgable about the products out there. I don't use AC, so I can only go off what I've been told.
‎2004-08-24 03:14 AM
ArchiCAD is the engine that drives the virtual building. All views on the model, e.g. plan, 3D, section/elevation, are all connected to the same source. If you change one, you change them all. You can only prevent this from happening in sections or elevations by explicitly telling ArchiCAD to unlink it from the model.I understand that part, that all views are linked. I guess what I was getting at, is let say you were ready to print the set. At the last minute, right before you print, you notice something on the sheet you need to change. Can you make that change on the sheet in Plotmaker? If yes, then will it update the model in ArchiCAD? Or if you need to make a change, you go back to ArchiCAD, make the change, then reopen Plotmaker? Do the Plotmaker sheets update automatically when the model changes?
If you are keen to learn about ArchiCAD, I suggest you pay a visit to your local ArchiCAD dealer and/or get the demo CDs. You will learn almost everything you want to know from there, and then you can come back with some informed questions.I want to learn more about all the competition. But this doesn't mean I have the time to get demo versions of ArchiCAD, Triforma, ADT, Briscnet, AllPlan, etc. etc. and try to learn them all.
Otherwise this questioning is tying up a lot of the forum's time and energy replying what appears to be a sales pitch for Revit coupled with deprecatory comments on ArchiCAD.My occasional post can hardly be consider to be tying up a lot of forum time in the overall amount of comments that get posted here. No sales pitch, no deprecatory comments intended. If I'm taking too much of your time, don't reply.
How can you justify spending so much time on this forum without any intention of using ArchiCAD or even trying the demo?I read this forum, most of the ADT/AutoCAD and other Autodesk NG's, and the Revit Forums at AUGI. It's about collecting information and getting educated. I like reading about and discussing this stuff.
