2d trace from google earth
Hi Guys,
Apologies if this is a noob question but I've had no luck searching for exactly how to do this.
Basically I have a survey plan that is not geolocated. I want to lay google earth imagery over the top and trace it to add details.
The problem is when I import the google earth imagery to archicad, I can't get the location and scale quite right as I don't know the exact lat/longs of the survey plan.
Any ideas how to accomplish this?
Regards,
Jon
1 REPLY 1
rgarand
You will need to have something to "align" to which is on both your survey and the google imagery. I have found that even when I have the correct lat./long. it is still quite hard to get a perfect alignment.
Robert J. Garand
ArchiCAD USA 28-Build 3110 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
