3D Cutaway toggle - is it real?
Ernest Atanasiu
as you can see in the attached image even if i don't have this option active i stiil see the building with cutaway plane.
there is no 3D cutting plane defined, also.
please help!
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
14 REPLIES 14
ravngrav wrote:
I found out that the bug was produced by... DOORS' KNOBS. When I removed all the doors and rebuilt the model everything was ok.
Good lord, how weird!
Does this happen with *all* knobs and handles, or just particular ones?
Wendy
gergazi wrote:
It is strange ;
Did you try the "delete all cutting planes" in 3d cutting planes
I've tried that, and it does not solve the problem.
Wendy
Djordje
Wendy
Not really, when you think about it.
Round knobs have gazilions of polygons; they can put quite a strain on the OpenGL engines/processors, who then clip away what is not seen of the model ...
... just guessing here, but it sounds probable
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Link
Just want to eliminate the obvious. 3D Cutaways are stored with 3D views. You're not reactivating a saved view are you? This just happens when you go to the 3D window (in the Project Map) right?
Link.
David Bearss
I love it!!
Compliments to you ravngrav. I can only imagine the eureka experienced when you made the discovery. Sharing info like that is what makes this forum so interesting and fun.
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
