‎2020-01-13 12:02 AM
‎2020-01-13 02:58 AM
‎2020-01-13 06:16 PM
Barry wrote:The F8 key will not do anything in any mode. What is the official command assigned to F8? I will look it up in the command list to see how I can try to activate it. But the 3D Explore mode locks out all keyboard keys or simply disables my keyboard.
If the ESC key is not working it could be something more serious, like another program running in the back ground that is hi-jacking the keys.
Otherwise try pressing the F8 key to toggle on/ff the parallel view.
One mode will only allow you to rotate the model with the mouse and the movement keys will be disabled.
The other mode allows you to explore as you would expect to.
‎2020-01-14 01:42 AM
‎2020-01-14 01:57 AM
‎2020-09-07 12:20 AM
Barry wrote:The problem of not having the keys working in Explorer mode to move around AND the Magic Wand tool does not work has happened again.
Seems to be a bit of a MAC issue?
I found these post that seem to say restarting works but it comes back.
Updating the OS seems to be the solution.
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=50351&hilit=explore+keys&start=10#p267031
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=51787&p=252159&hilit=explore+keys#p254855
This one is more for all shortcuts but does mention Explore mode.
It seems there could be a few problems/solutions.
Language settings.
OS update.
Re-apply Work Environment.
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=5773
Maybe it will be best to contact you local Archicad support before playing around with updates.
‎2021-01-22 01:41 AM
‎2021-01-22 02:53 AM
‎2021-01-22 09:56 PM
‎2021-01-27 02:05 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
