Chris Grantham
3D Model Clipped
For some reason my model is being clipped as if I have a marquee around it, but I do not. I have restarted the program and the computer to no avail. Anyone have any ideas?
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
5 Replies 5
Link
With nothing selected, right click in an empty area in the 3D window and select 'Show All in 3D'. Maybe you just hit F3 to go to the 3D window and doing that remembers what was last there. Try using F5 or ctrl/cmd+F5 instead.
Link.
Check for 3D cutting planes.
Go to:
View > Elements in 3D View > 3D Cutting Planes
and:
View > Elements in 3D View > 3D Cutaway
Chris Grantham
Thanks for the quick response Link. It is definitely not that as I always use F4. I have also investigated the "clipping plane of death", but I do not believe it to be that either as the problem persists in axonometric view...
Mac OS 26
Chris Grantham
Thanks Matthew! Must have hit command-y when I was going for command-t.
Mac OS 26
Link
Cutting planes would have been the next thing. Glad you got it sorted!
Link.
