2006-01-31 11:05 AM
2006-01-31 11:14 AM
2006-02-01 04:37 AM
Jus wrote:Where are you looking at it from?
I've imported a DWG and have started to trace the buildings however, when I go to the 3D view everything is upside down.
2006-02-01 04:52 AM
Jus wrote:the DWG is a 3D object?
Is there any way I can orbit the DWG and trace on the other side so that the 3D view will be the right way? Any ideas why this is happening ?
2006-02-01 02:10 PM
2006-02-01 09:46 PM
Z.Bauer wrote:the distance between the camera and target is very very small - many this has the effect of flipping it over? bug for sure, but what happens if you use the 'look-to' button to increase the length of the viewpoint?
Upside down problem persist, if model is rendered from perspective top view (see attached screenshot).
2006-02-02 05:41 PM
2006-02-02 10:00 PM
Jus wrote:do you have any cameras placed? and if so do they have a 'roll angle' of 180º instead of 0º?
The reset buttons make no difference to it.
2006-02-03 12:46 PM
~/archiben wrote:Same result if you use "look to" button.
...bug for sure, but what happens if you use the 'look-to' button to increase the length of the viewpoint?
~/archiben
