3D WINDOW WARNING
I am currently working on a project at work on a site of around 180 houses. I have put most of the site in 3D and hope to have completed the full site in about another week.
When I have went into the 3D window lately it has come up a few times,
WARNING- DISK IS FULL OR NOT ENOUGH MEMORY TO CREATE 3D DATA STRUCTURE.(ERROR CODE:22)
Has this happened to any other Archicad users?? and what would the problem be ??
At work I am using Archicad 9 on a 3.0 GHz PC with 1.5 GB of RAM with a NIVIDIA graphics card and have also got a laptop which is A 2.0 GHz intel Centrino Pentium M processor 755, 1GB of RAM and 160GB HARD DRIVE the laptop also has a NIVIDIA Geforce FX Go5700 graphics card.
This problem does not happen all the time but would happen lately sometimes. The house types I am doing are fully detailed and this is a pretty big model in 3D. Although I would have thought, I would of had enough hardware to deal with this problem.
If this has happened anyone before or you know what this is down to??, I would be grateful if you could assist me on fixing this problem.
Stephen Kerr
Micheal Rogers Architects
1 REPLY 1
Dwight
free space on disk? Check with ArchiCAD off. A 3D temporary file can be big.
Dwight Atkinson
