We value your input!
3D Window non responsive and blank
Would be most grateful for some further light and knowledge. My 3D window has suddenly become non responsive and I can't see the model even the 'Fit To Window' does not have any effect. I have also noticed that the one elevation is fixed to a wireframe view (the others are ok) so take it that while trying to select/zoom to the model I have unwittingly screwed something else up. Any help on the matter; please.
2 REPLIES 2
Lingwisyer
Guru
Just querying, which version of AC is this? 19? And what is your computer like? See signature.
Ling.
I have no idea what the problem may be but I saw a laptop yesterday where there was no 3D when using the vectorial engine.
I wasn't able to play with it long enough to figure out what the actual problem was.
Try switching between vectorial and OpenGL to see if that makes a difference.
Using OpenGL worked on the laptop.
Also test the regular culprits.
Try using different Model View Options, Renovation Filters and Graphic Override combinations to see if that makes any difference.
