3D cut view question....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-05-20
01:26 PM
2023-05-23
02:26 PM
Rubia Torres
Is it possible to make a 3D window cut view that allows me to cut away a portion of the model but only on a certain story, leaving the other stories visible and intact?
For example, I want to be able to make a cut view looking into the corner of a building, cutting away a section of the interior and exterior walls, the roof and ceiling but leaving the ground floor slab intact and still visible.
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-20 02:24 PM
I think the only way is to use SEO. But the operator(s) will need to be moved away from the model for other complete views (cannot be turned on/off).
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-20 02:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-20 05:17 PM
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-21 03:14 PM
Link wrote:Enable the "Trim Elements to Marquee" box.
Interesting that a 3D Marquee doesn't work when set to show elements outside marquee.
There is not as much control over the vertical cut heights using that method vs. SEO.
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-21 03:33 PM
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-21 07:07 PM
Would be nice if AC had a 3D marquee object, visible on the 2D plan view as well as 3D window.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-25 10:43 PM
Here's a post I wrote about it a while back:
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-27 05:48 PM
JaredBanks wrote:Ive tried experimenting with SOE and the layer intersection groups. Unless Im doing something wrong it doesnt seem to have an effect.
It is (or was) possible to make SEO turn on or off with Layer Intersection Groups. I haven't tried the trick in years, so I don't know how well it works in 18 (or 19). But if you set the Operator Layer to have a 0 Layer Intersection Group, it theoretically shouldn't interact with other elements.
http://www.shoegnome.com/2011/06/19/conditional-operatorsv1/
I also played around with using a material set to highest strength to cut the model which gives interesting results as obviously PBC will only work with certain building elements.
