3D dimensions
When I go to the 3D document window, the linear dimension tool is locked and I cant press it. Why is this happening?
Thanks in advance!
I think this has been addressed somewhere else but you need to save the 3D view as a 3D document 1st and then the tools are available.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
ruben, I see you are using INT.
That might be true for INT version,or other versions, I really don't know.
However, I immediately have dimensioning active
once 3dd is created in U.S. build 2285.
It automatically switches to 3dd
Bier
Thanks a lot,
I didn't now about 3D documents.
I owe you one!
Cheers!
