windows dissappeared
Help me out!
Windows suddenly dissaperaed in 2D. not even are they as "missing". In 3D they are completely visible and operateble.
in the last time we came on version 12. The project started with ver.11.
What could be the problem???
Leonard wrote:
Help me out!
Check your model view options.
You probably have the windows set to show as openings only or not at all if you can't even see the openings.
If that isn't it check that the Floor Plan Display option in the window object settings is set to "Symbolic".
