3D model missing
RobiLMan
So my floor plans are working perfectly even section but my 3D modeling view is just blank paper. Anyone knows how to fix that?
RobiLMan
sorry for the lack of information, I just started using archicad 3 days ago and Im using some "profile" made by a teacher in Czech republic and i found a different way to see my 3D model. Im gonna call this case as solved. Thanks anyways.
Not missing,,, but for whatever reason you are not seeing it.  There are dozens of possibilities and you give us no information about how you are trying to view the 3D.  Have you started with an out of the box template?  Or are you using a 3D view from Navigator, or are you just pressing F3?
The most common reason for not seeing the model is being in a perspective view with the “camera” not looking at the model.   As I said, dozens of other possibilities, all easily addressed and someone else might feel like typing,
RobiLMan
For future reference:
Here are a few reasons why elements may not be visible:
https://community.graphisoft.com/t5/Documentation/Missing-elements-Troubleshooting-Guide/ta-p/303545
Setup info provided by author
