3D people stomach not there in render view
Is there a bug with 3D people stomach not there in render view. I'm rendering a view and no ones stomach is there.
Thanks,
Michele
8 REPLIES 8
Aaron Bourgoin
Michele,
I think you're right. My people look like they've just stepped out of a Monty Python animation.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Djordje
Within a marquee or in any case?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I did mine within a marquee but I'm going to need to do a marquee every time I render so for me it happens all the time.
Michele
Djordje
Try selection set and a saved view.
Djordje
HP Omen
I change camera angles and add things or change things and then I'd have to redo the selection set right? It's just seems less time consuming to just marquee it.
Michele
I'll give it a try.
Djordje
Just redefine the view. No, it is not easier to marquee it. Move the camera, use OpenGL - or create new cameras.
In general, don't use the marquee for the final renderings, many of not-so-old lib parts lose pieces.
Djordje
HP Omen
I have had the same problems myself, and yes it all boils down to the marquee!
It's sad that the standard object doesn't work with the standard marquee. The marquee is great for creating perspectives and isometrics of fragments of the building (showing the 'CUTPLANES', that is). Selecting cannot do that.
