2017-05-11 07:27 AM - last edited on 2023-05-23 04:15 PM by Rubia Torres
2017-05-12 07:56 AM
Barry wrote:Thanks Barry. I think I got to the bottom of it. I did a bit of photoshopping and painted a big red arrow on this specific JPEG texture then loaded it in and replaced it with the current timber cladding texture I have.
I think the problem is exaggerated with your texture because the start and end planks are cut in half but are not exactly the same width.
So when the texture is aligned one way it will be in a slightly different position when rotated 180°.
2017-05-12 07:59 AM - last edited on 2021-10-22 04:53 PM by Laszlo Nagy
Also, I have had quite a few instances where I'm trying to paint an object with surface and this dialogue box appears. I have searched far and wide and have not been able to find any help on this. Any thoughts?
2017-05-12 10:49 AM
benjamin_chan wrote:The textures should all be the same direction until you start playing with them.
What determines the direction in which the surfaces are painted on the walls and how can I make them all go the same way? Walls do not seem to be able to "set direction" for 3D surfaces.
EDIT: Nevermind - got it! I just had to reset the texture.
2017-05-12 10:59 AM
benjamin_chan wrote:It is a bit hard to find as there in no index item for 'Paint' or Surface Paint' - you have to know to look for 'Override Surfaces'.
2017-05-12 11:25 AM
Barry wrote:Thanks Barry.benjamin_chan wrote:It is a bit hard to find as there in no index item for 'Paint' or Surface Paint' - you have to know to look for 'Override Surfaces'.
It is just saying that you can TAB key to select all faces or just the one you clicked.
2019-01-09 11:47 PM
2019-01-09 11:52 PM
2019-01-10 10:26 AM
