3D visual with cut walls...
Llian
Please direct me to a video to do this: partial [cut ] wall...
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
5 REPLIES 5
You have cutting planes available in 3D, but you can't really pick and choose what you do or don't want to cut.
I would add a slab in a special 'operator' layer that you can turn off.
Make that slab your operator and select the walls (and any other elements) you want to cut and make them the targets.
Do a Solid Element Operation (subtract with upwards extrusion).
Turn the 'operator' layer off and there you go.
Llian
Thanks Barry. Yes, SEO and the layer…haven't done that for ages.
Gerry Leonor
if you're not doing any rendering, i'd probably use 2 saved 3D views both using a 3D cutting plane:
  1. a 3D cutting plane for the short wall that shows all the interior stuff
  2. a 3D cutting plane for the taller wall that hides all the interior stuff
stitch them together in the layout but putting them on top of each other, & cropping the boundaries of the drawings to show/hide the elements as needed.
AC25 | Win11 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
Gordana Radonic
Community Manager
Community Manager
You can also use Building Material's intersection priority. Make one material to be air to make it invisible and make highest priority, so you can place it from the height of the wall you want to hide.
Gordana Radonić
Community Manager
Hello Llian,
In addition to Barry's post and to get slices of gray walls you need to check the attributes of the operator in SEO (gray or red or which color you want by your operator).
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
