‎2017-10-10
09:41 PM
- last edited on
‎2023-05-26
02:14 PM
by
Rubia Torres
‎2017-10-11 02:40 AM
‎2017-10-11 11:27 AM
Barry wrote:Hello Barry, thanks for taking the time to reply! I checked the menu you mentioned and I did have the 'Infinite' option marked already so unfortunately that is not the fix 😕
Check your 'Filter & Cut Elements in 3D' settings (CTRL+ALT+A for Windows).
You may be limiting the 3D view there.
‎2017-10-11 12:09 PM
‎2017-10-11 12:20 PM
Erwin wrote:There was indeed the issue! Thank you very much!
Check your Grids & Background settings. Sounds to me like the editing grid background has gone solid. It has default position of 0 in 3D and is allways on, unless you set it up to behave otherwise.
