3d Document Contours??
Hello:
By setting 3d engine "Internal" and using "Draft" in contours options inside 3d Windows setting, im able to see the countours of my model.
The problem is that when i create a 3d document of that view most contours are not visible again.
Is there anything i can do? (Currently using Archicad 16).
Thanks!.
Did you rebuild the 3D document after the change?
Right-click the 3D Document in the Project Map and the command is there in the context menu.
Hi:
yes, i rebuild it and nothing changed .
Hm... strange problem. I tried just now and the 3D Window contour setting does not seem to have anything to do with how contours are displayed in the 3D Document Viewpoints. For me they are always displayed.
Can you post a screenshot? I am wondering if this could be a graphics card driver problem, you might try upgrading its driver.
